Synchronous rectification
Discussion in 'General Electronics Chat' started by Gaurav:), Dec 24, 2013.
  1. Gaurav:)
    Dec 24, 2013
    Hi.. I am working on a full wave bridged topology of SMPS. My power requirement is more than 3KW including 200 A of current. I am using IGBT H bridge at the primary of SMPS and MOSFET H bridge at the secondary. I am driving primary side IGBTs using microcontroller generated PWM. I need to drive MOSFETs using these PWM signals. Should I go for the isolation or pulse transformer?
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    I would think a pulse transformer is an isolation transformer. So what is your question?
  3. Gaurav:)
    Dec 24, 2013
    I mean, Should I go for the pulse transformer or use IR 2110?
  4. ErnieM
    Apr 24, 2011
    7,436
    1,626
    That depends on your topology and if you require isolation, would it not?
    If you require any more detail just ask and I shall consult my magic 8-ball.
    Gaurav:) likes this.
  5. Gaurav:)
    Dec 24, 2013
    Thank you for your response sir. I am using Full bridge, the standard isolated topology. Can I vary the output current by varying the duty cycle of the PWM signals at primary? Can output inductor decide the value of the maximum output current?
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Do you really want to try to build a 3kW SMPS with dual switched h-bridges and synchronous rectification, at your level of skill? :eek:
  7. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Good question.
    Seems some folks are always interested in building UPS's under the false assumption it's cheaper than buying one. I'm assuming this is a UPS and not a power supply.
  8. RamaD
    Dec 4, 2009
    254
    33
    OnSemi has made a comparison of GDTs and their silicon solutions in an AN, and finally recommended their silicon solutions with a no. of reasons. The top one is :
    We dont make transformers :)
  9. Gaurav:)
    Dec 24, 2013
    If you guys can't help me out at you level of skills then whats the use of your so called 'SKILLS'??
  10. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Okey dokey. What are you building, what's it for? Post your schematic. Some form of 200A, 15V power supply?
  11. RobeeJ
    Mar 19, 2013
    24
    I think it's for the Darwin Awards.
