synchronous handshake
Discussion in 'Homework Help' started by ][ Shocked ][, Jan 4, 2010.
  1. ][ Shocked ][
    Apr 13, 2009
    22
    Hello everybody
    my teacher gave us a project to do
    it's about synchronous handshake
    we need to implement it using FF
    this is the project
    http://faculty.kfupm.edu.sa/ee/msharawi/Project_2_091.pdf
    it's said there we have 5 states and the rest consider them zeroes
    where did he got the 5 states from?
    are Request, Acknowledge & Rest the three states we should take care of
    and are acting as inputs to the sequentioal circuit?
    and what is the relation between these three inputs and the output Error
    I'm not getting it
    when do we have Errores?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. ][ Shocked ][
    Apr 13, 2009
    22
    im still not getting it
    here is the state diagram
    but what are A, B ... ?
    and how does connect A with C !?
  4. DigitalLogician
    Dec 20, 2009
    5
    Your task is to create a circuit that outputs a 0 (or a 1 with inverter) as long as the inputs run through a gray code loop: 00 - 10 - 11 -01 - 00, etc. Any deviation from this sequence will result in an error. Try starting your design using data latches. Here are a few to help you started:
    http://www.teahlab.com/multivibrators/positive-edged-triggered-D-Flipflop/Dflipflop.html
    http://www.teahlab.com/multivibrators/masterslavedflipflop/masterslavedflipflop.html
    http://www.teahlab.com/multivibrators/DataLatchRSbased/datalatchrsbased.html
    http://www.teahlab.com/multivibrators/gated-D-latch_Norbase/DLatchV02.html
    If after doing some leg work you are still stuck let me know.
