Synchronous counter with D flip flop help
Discussion in 'Homework Help' started by rocky86, Nov 29, 2010.
  1. rocky86
    Nov 29, 2010
    Hi guys i need help with this problem! is from my uni past year paper, reallx do not noe how to do!
  2. retched
    Dec 5, 2009
    5,201
    313
  3. rocky86
    Nov 29, 2010
    I understand the video, however i still do not noe how to solve the problem because it appear the sequence of the states is different due to the condition on the question!~
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Try drawing the gates from the outputs to the inputs for Da, Db, and Dc using the logic specified. Then work through it as shown in the video.
  5. blah2222
    May 3, 2010
    565
    33
    This isn't too bad because they are D flip-flops and they are all synchronized (clocks are all the connected). They are all positive-edge triggered. So to simplify all this, they are all going to change at the same time.
    Initial Conditions:
    Qc = 0
    Qb = 0
    Qc = 0
    So, since these are positive-edge triggered D flip-flops, every positive edge of the clock will cause all the D's to pass their values to the Q's.
    So, the next rising edge will cause:
    Qc = Dc
    Qb = Db
    Qa = Da
    The D values are calculated from the previous Q values.
    Dc = Qa + Qb
    Db = Qa'Qb + Qc'
    Da = QbQc
    So given that the first sequence is 000, the following will occur before the next rising edge of the clock:
    Dc = 0 + 0 = 0
    Db = 0'0 + 0' = 10 + 1 = 1
    Da = 00 = 0
    These values are then passed to the Q's on the next rising edge of the clock, then the process continues.
    Try it out yourself, but this is what you should get:
    000
    010
    110
    111
    101
    100
    000
    ...repeat
    So now that we know the pattern, you can find out what the output would be at any amount of rising clock pulses.
