Synchronous Counter (16 bits?)
Discussion in 'The Projects Forum' started by Salvatore, Mar 9, 2016.
  1. Salvatore
    Mar 9, 2016
    6
    Hello people of the AAC community (I'm new to the AAC forums, so bear with me).
    So, to the point. I am given by a teacher this project:
    Create and design a Synchronous Counter that starts from the number 42110 reaches 103110 and restarts (a loop from 421 to 1031).
    I have to use one of these ics: 74ls163, 74ls191, 74ls93 (in the quantity that's needed) and a Timer555 in burst mode (astable).
    I think that i'll go with 4 ics of 74ls163 (correct me if i'm wrong, regarding the number of ics needed). We want the timer to give pulses every 1-2sec (what are the R and C values to achieve that)?
    I would appreciate it if you could help me with the design (schematics, wiring etc).
    Thanks in advance,
    Salvatore
  2. blocco a spirale
    Jun 18, 2008
    1,455
    369
    I'm sure your teacher would appreciate it if you do the design for your project.
  3. Salvatore
    Mar 9, 2016
    6
    Don't get me wrong, i don't want anyone to do the hard job for me. As far as i know the design will be based on this logic[​IMG]
    Also i know that i must use the proper logic ics to make the counter stop at 1031. What i want from the people of the forum is to give me some answers on what I ask above and to give me any help they are willing to give. That's all. Sorry for the misunderstanding (and also for my mediocre use of the English language).
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,677
    1,294
    Step 3 - the 555 timing components are indicated in a graph in the datasheet.
    Step 2 - Do the start and end count values have any characteristics that make this problem easier?
    Step 1 - Why 4 counter chips? How many bits does the entire count cycle span? How many chips to cover this span? Why?
    ak
  5. hp1729
    Nov 23, 2015
    2,067
    230
    Your counters are PRESETTABLE? Preset to 421 on a count of 1031.
  6. Salvatore
    Mar 9, 2016
    6
    thanks for the help. The preset number is 421 (decimal) and we want to count till i get to 1031 (decimal). Since the counters will count in binary i thought that 4 4bit counters give us 16 bits since 1031 in binary is 0000010000000111
  7. Salvatore
    Mar 9, 2016
    6
    and you lost me. :p i guess the counters must be presetable since i want the count to start from 421 (decimal)
  8. blocco a spirale
    Jun 18, 2008
    1,455
    369
    You need 11 bits to count to 1031, so why not use 3x 4-bit counters?
  9. Salvatore
    Mar 9, 2016
    6
    i guess you are right since these (0000)010000000111 aren't going to change
  10. absf
    Dec 29, 2010
    1,493
    374
    Do you need to display the result in 7 segment LED or discrete LED?
  11. AnalogKid
    Aug 1, 2013
    4,677
    1,294
    GUYS - THIS IS HOMEWORK. THE QUESTIONS WERE FOR *H*I*M*.
  12. hp1729
    Nov 23, 2015
    2,067
    230
    Look at the data sheets for the ICs suggested.
  13. absf
    Dec 29, 2010
    1,493
    374
    You can preset the counter to 421 during power-up and preset it when it has reach the count 1031 using some 2-inputs gates.
    Allen
    Salvatore likes this.
  14. hp1729
    Nov 23, 2015
    2,067
    230
    http://www.electronicspoint.com/threads/presettable-counters.277927/
    Data sheets will often include basic application examples.
  15. hp1729
    Nov 23, 2015
    2,067
    230
    Not really. 10-bit Ripple Carry Out + a few counts.
  16. Salvatore
    Mar 9, 2016
    6
    thanks for the help you provided me with, everyone. I think i'll start the project on monday. Hope it goes as planned
