synchronize pic18f4550 pwm with external signal
Discussion in 'Embedded Systems and Microcontrollers' started by isolete_m, Jun 12, 2016.
  1. isolete_m
    Jun 12, 2016
    I want to control the trigger angle of a triac connected to AC power (60Hz). My guess is that I can do it by changing the duty cycle of a 120Hz pwm generated by the PIC.
    I have a zero crossing detector circuit that generates a pulse on every semicycle start, but I can't figure how am I supposed to synchronize it with the pwm. Since I can't generate exactly 120Hz (closest I got was 122Hz), I have to reset (restart) the PWM period everytime I receive the zerocrossing pulse, but I don't really get how to do it.. Any help would be appreciated.
    I'm using PIC18f4550 with XC8 compiler on MPLAB IDE.
    Thanks!
  2. John P
    Oct 14, 2008
    1,638
    225
    I don't see why you need a PWM signal. I've had to do this, to operate a vibrating conveyor that ran off the power line, and I just set up a trigger that operated from a zero crossing (an optoisolator, as I recall) and then generated a time interval from that, to produce the "on" time for the power control element. No PWM needed, because each cycle was individually triggered and timed.
  3. dannyf
    Sep 13, 2015
    2,196
    417
    Your guess would be completely wrong.
