Synchorous counter with parallel load
Discussion in 'Homework Help' started by nyasha, Oct 26, 2010.
  1. nyasha
    Thread Starter Active Member
    Mar 23, 2009
    90
    Is my design correct ?
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
    Unfortunately, no.
    The idea of using a MUX to select between input and counting is correct, but:
    The counter itself is wrong. See here: http://www.allaboutcircuits.com/vol_4/chpt_11/3.html for correct counter circuits.
    The input method is wrong. A T-Flip Flop doesn't store what it is fed, unlike the D-FF. Therefore, feeding it the desired bit doesn't mean it will be stored too. You should find a way to handle the T-FF to make it do what you want (hint: XOR gate). Alternatively, you can switch for a D-FF (which will change the counter circuit, too).
