Guys,
need some advice to confirm if below statement require to write sync or async assembly language program...For you information, i am doing a multifunction calculator...using M68HC11 microcontroller with assembly language to interface...
"This value must then be continuously transmitted serially and it should be able to be viewed on the
calculators display at the users discretion. The calculators serial communications will operate at
9600 BAUD with 8 data bits 1 start bit, 1 stop bit and no parity."
Thanks,
ANthony
Thanks,
ANthony
