Symmetry in circuits involving Resistors
Discussion in 'Homework Help' started by logearav, Nov 18, 2015.
  1. logearav
    Aug 19, 2011
    248
    Hello friends,
    Find attached a problem involving symmetry in circuits involving resistors. Its been mentioned that by symmetry the current in part ab and ad will be equal.
    The current i branches to part d, o and b at the same time. Then how could symmetry is applicable only in ad and ab not ao?
  2. logearav
    Aug 19, 2011
    248
    Also please refer the following attachment too.
    Why there is symmetry as mentioned?
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    Are the resistors all the same value? That's critically important to know.
    Assuming so, who says that it doesn't apply to ao?
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Well, look at those two branches. Is there any reason for the current in one to be different than the current in the other?
  5. logearav
    Aug 19, 2011
    248
    Thanks Mr.WBahn. By symmetry does it mean that the magnitude of current is same in every branch?
    Yes, the resistances are of equal value.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Symmetry does not necessarily mean that the magnitude of the current is the same in every branch, just in those to which the particular symmetry argument applies.
  7. logearav
    Aug 19, 2011
    248
    Thanks. So what exactly symmetry means with respect to current, sir?
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    It means that there is no reason for the current in one resistor to be different than the other. The usual test for this is that you could swap the paths and nothing would change.
