Symmetric 555 oscillation
Discussion in 'General Electronics Chat' started by lotusmoon, Jun 14, 2013.
  1. lotusmoon
    Jun 14, 2013
    203
    Mod edit: This thread was split from here: http://forum.allaboutcircuits.com/showthread.php?t=86130
    Please do not hijack other members' threads.
    I am new to electronics, but wanted to make a strobe with different frequencies.
    I have this formula for a 555 timer cycle
    t1 = .693 x (R1+R2) x C
    t2 = .693 x R2 x C
    t1 = time on and t2 = time off
    from this formula it does not seem possible to have an equal t1 and t2. could some one let me know if there is a way to have them equal?
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    Please don't hijack someone else's thread as it creates massive confusion. Instead, start one of your own. Don't do that now, though; I've reported your post and a moderator will probably split it off into its own thread in the near future.
    This is a question that has been addressed many times and in many places here. I don't have a specific link to give you, but search the forum (and also the blogs) for something like "555 equal on off" or "symmetric 555 oscillator" and you will probably find something quickly.
  3. lotusmoon
    Jun 14, 2013
    203
    sorry about that I thought I had posted a new thread, I will look for things you have mentioned thank you
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It's best to use a different circuit. There is an astable 555 timer circuit driving the threshold cap from pin 3 (does not use the discharge pin 7).
    That circuit is simpler and gives a good 50% duty cycle at all speeds (especially with CMOS 555 chips like the 7555).
  5. ErnieM
    Apr 24, 2011
    7,439
    1,627
    Correct, but if you make R2 much greater then R1 then the on and off time get very close in time.
  6. lotusmoon
    Jun 14, 2013
    203
    "It's best to use a different circuit. There is an astable 555 timer circuit driving the threshold cap from pin 3 (does not use the discharge pin 7).
    thank you"
    thank you - do you have a link to this circuit circuit?
  7. JoeJester
    Apr 26, 2005
    3,402
    1,225
    Here's one from Williamson's Lab ....
  8. KL7AJ
    Nov 4, 2008
    2,047
    295
    Indeed it is not, but you can make it very close to symmetrical by making R1 very small relative to R2.
    Eric
  9. MrChips
    Oct 2, 2009
    12,636
    3,455
    Symmetrical clock signals are rarely a necessity.
    To create a symmetrical signal from a 555 timer circuit, output a signal at twice the desired frequency and feed it into a toggle flip-flop (T-type flip-flop).
    You can use a D-type or J-K flip-flop to create a toggle flip-flop.
  10. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Nah, you don't need those messy diodes. :)
    Here's the circuit, it only needs a 555, 1 resistor and 1 cap;
    If you replace the resistor with a pot and resistor in series you get variable frequency but still has 50:50 duty cycle.
    lotusmoon likes this.
  11. lotusmoon
    Jun 14, 2013
    203
    That's brilliant I wanted a variable frequency. is possible to work out and fix the beginning and end of the variable frequency? ie 1Hz - 100Hz
  12. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Yep. If you use a 1k resistor in series with a 100k pot, the frequency adjustment range will be approximately 100:1.
    As for the actual Hz, try plugging in different caps (and you may need two caps in parallel) until you get roughly 1Hz to 100Hz.
  13. lotusmoon
    Jun 14, 2013
    203
    I have been told capacitors are up to 20% inaccurate which would make it hard to accurately calculate the frequency is this true?
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    That's part of it, and the 555 output will have some impedance that will also affect the calcs.
    Just plug in some different caps, it's very fast to test and settle ona cap value. Example; If your first cap runs 5 times too fast you know you need a cap about 5 times larger.
  15. k7elp60
    Nov 4, 2008
    479
    69
    Not true use a mylar film capacitor and this formula to determing the value of resistor and capacitor: f= 0.722/R1C.
