I'm pretty new to programming and just wanted to put this sample program into my 16f84 to see if everything is ok with my programmer device, my pic and other stuff..
but when i "build all" it gives these three error;
Error[113] C:\USERS\UMIT SEDGI\DESKTOP\PROJECTS\MPFIRST.ASM 46 : Symbol not previously defined (B00000000)
Warning[224] C:\USERS\UMIT SEDGI\DESKTOP\PROJECTS\MPFIRST.ASM 47 : Use of this instruction is not recommended.
Error[113] C:\USERS\UMIT SEDGI\DESKTOP\PROJECTS\MPFIRST.ASM 49 : Symbol not previously defined (B00000001)
Helps are highly appreciated in advance...
thanks
; File: LEDOn.asm
; Date: June 1,2006
; Author: Julio Sanchez
; Processor: 16F84A
; Description:
; Turn on LED wired to Port-B, line 0
; switches
; Switches used in __config directive:
; _CP_ON Code protection ON/OFF
; * _CP_OFF
; * _PWRTE_ON Power-up timer ON/OFF
; _PWRTE_OFF
; _WDT_ON Watchdog timer ON/OFF
; * _WDT_OFF
; _LP_OSC Low power crystal occilator
; * _XT_OSC External parallel resonator/crystal oscillator
; _HS_OSC High speed crystal resonator (8 to 10 MHz)
; Resonator: Murate Erie CSA8.00MG = 8 MHz
; _RC_OSC Resistor/capacitor oscillator
; |_____ * indicates setup values
processor 16f84A
include <p16f84A.inc>
__config _XT_OSC & _WDT_OFF & _PWRTE_ON & _CP_OFF
; variables in PIC RAM
; None used
; m a i n p r o g r a m
org 0 ; start at address 0
goto main
; space for interrupt handler
org 0x04
; main program
main:
; Initialize all line in Port-B for output
movlw B00000000 ; w = 00000000 binary
tris PORTB ; Set up Port-B for output
; Turn on line 0 in Port-B. All others remain off
movlw B00000001
; | |____ Line 0 ON
; |________ All others off
movwf PORTB
; Endless loop intentionally hangs up program
wait:
goto wait
end
thanks
; File: LEDOn.asm
; Date: June 1,2006
; Processor: 16F84A
; Description:
; switches
; * _CP_OFF
; _PWRTE_OFF
; * _WDT_OFF
processor 16f84A
; None used
goto main
org 0x04
; main program
main:
movlw B00000001
; | |____ Line 0 ON
movwf PORTB
wait:
goto wait
end
