symbol help
Discussion in 'Homework Help' started by amilton542, Dec 30, 2010.
  1. amilton542
    Thread Starter Active Member
    Nov 13, 2010
    494
    64
    some of the formulas ive been looking at are containing symbols i dont understand and there not saying what they mean :confused:
    here are the symbols i dont get:
    Ʃ - ive also been coming across this with a ∞ above it, does this mean infinite?
    ∫ - i think this means inertia but what does inertia mean? ive also seen three of these in a row one after the other, sometimes with a circle in the middle, i think that means at any point.
    . - i presume the full stop is multiply ?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. shteii01
    Feb 19, 2010
    3,504
    512
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Σ is for sum. It usually comes with a variable term that is summed over and over.
    For example \Sigma _{\tiny{i=1}} ^{\tiny4} i=10
    \int is for integration. Multiple integration signs mean integration in more than one dimension. A circle denotes integration over a closed line.
    For example \int _0 ^5 x\ dx=\left[ x^2 \right] _0 ^5=25
    As for the dot, it depends on its position in the expression. Can you be more specific?
  5. amilton542
    Nov 13, 2010
    494
    64
    thanks guys it doesnt look as scary anymore. ok i can be more specific with the . , for e.g there will be an upside down triangle . B = 0. i think i need to work on my maths, i been reading a book on magnetism and magnetic materials and its all maths way beyond me
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The upside down triangle is called "del" and it is a differential operator. See the following article:
    http://en.wikipedia.org/wiki/Del
    The interpretation depends on the thing it is applied to. This stuff isn't easy and a quick review is unlikely to be sufficient if you've never seen it before.
  7. amilton542
    Nov 13, 2010
    494
    64
    ok thanks, these wikipedia print outs has provided me with more than enough for today. how long will this take to grasp to understand properly?because this does seem hard. i do about 15-20 hours a week self direct research
  8. shteii01
    Feb 19, 2010
    3,504
    512
    The sum is easy, it is basically an abbreviation.
    Integral is more complex, but there are formulas that let you go from the integral to integral solution, basically someone in the past 300 years solved that particular type of integral, all you have to do is setup the integral, then look up in the list which type your integral match: http://en.wikipedia.org/wiki/Lists_of_integrals
  9. amilton542
    Nov 13, 2010
    494
    64
    are there any youtube lectures on this? i dont no what to type to find what im looking for
  10. shteii01
    Feb 19, 2010
    3,504
    512
  11. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It took me about four semesters of math and physics courses to really grab onto what was happening with calculus, vectors, and vector differential operators. That is about halfway to an undergraduate degree in Electrical Engineering
  12. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    A lot of this deals with calculus. Many electronics circuits operate around the math of calculus, so it is there. This isn't as bad as it sounds though, once you understand the basics most of the formula are already developed.
