Swtiching Scheme; light intensity based switching (PHOTOSWITCH)
Jbfaheem
Joined Mar 8, 2016
I want a switching scheme.
I want to switch between two circuits based on light intensity sensing. I want my circuit to sense light input from sun (i am working on solar panels) and switch between two circuits according to radiance levels. So, what i basically need is "light intensity based switching".
My Requirements are:
Switching time should be very less to ensure power regulation.
Components employed should be economical and easily available.
Possible Solutions:
Solutions that i thought are:
Use of
1. photo switch
2. phototransistors and relays.
I want to ask if there any adjustable photswitch available that switches on our required values of irradiance?
Do any One have any circuit diagrams employing phototransistors to switch between 2 circuits?
All suggestions are welcomed.
ian field
Joined Oct 27, 2012
6,536
Possible Solutions:
Use of
1. photo switch
You need a Schmitt trigger so the switching is clean and not flickering back and forth.
LDRs are getting hard to come by because the cadmium sulphide is too toxic for RoHS.
Sunlight contains enough IR that you can get away with a bog standard photo diode like they used to use in TV front panel remote sensors - all the modern ones are integrated with amplifier and 38kHz filter.
Most solar garden lights directly sense from the solar panel whether to light up or not - reverse engineering a few of those could give some answers, but recent ones have that function integrated into a custom chip.
Bernard
Joined Aug 7, 2008
5,784
Comments on sensors:
Light dependent resistor, LDR, showed little change in resistance with large changes in angle to sun.
Might be better if used with a filter.
Best results were with a single cell solar cell giving .56 V in full sun & @ .36 V when loaded with a .39 ohm R gave detectable V changes with small angle changes.
' would use a comparator, relay driver, & SPDT relay. NC to charge battery NO on at high sun to other load.
Alec_t
Joined Sep 17, 2013
14,333
Further to post #2, can you use your solar panel output current and/or voltage as the signal to control the switching?
ian field
Joined Oct 27, 2012
6,536
Not a filter - just attach a bit of tube so only perpendicular light can strike the sensor.
