Ch, Freq (MHz)
1, 26.965
2, 26.975
3, 26.985
--, 26,995 (Not legal for CB)
4, 27.005
5, 27.015
6, 27.025
7, 27.035
--, 27.045 (Not legal for CB)
8, 27.055
9, 27.065
10, 27.075
11, 27.085
--, 27.095 (Not legal for CB)
12, 27.105
13, 27.115
14, 27.125
15, 27.135
--, 27.145 (Not legal for CB)
16, 27.155
17, 27.165
18, 27.175
19, 27.185
--, 27.195 (Not legal for CB)
20, 27.205
21, 27.215
22, 27.225
24, 27.235
25, 27.245
23, 27.255 (Note:out of sequence; from early CB allocation)
26, 27.265
27, 27.275
28, 27.285
29, 27.295
30, 27.305
31, 27.315
32, 27.325
33, 27.335
34, 27.345
35, 27.355
36, 27.365
37, 27.375
38, 27.385
39, 27.395
40, 27.405
the 102" 1/4 wave ss whip needs a hefty base mount, which i dont have. for my needs (a whimpy 4w max handheld cb) my vswr ranges from 1:1 to 2:1 and the cb radio power meter peaks out on the 4w line across all channels. for now this is acceptable. when/if i go to a better radio cb i might think about doing a better antenna setup....If you are planning on using a ground plane I would highly suggest going to Radioshack and picking up a 102" Stainless steel whip antenna. If you run that and still have high SWR's you can be rest assured it's not the antenna as I have gotten a max SWR of 1.1:1 across all channels with this antenna on my Jeep. The only variable to deal with after that is the coax and ground.
Thread starter | Similar threads | Forum | Replies | Date |
R | Smart electric meters | Test & Measurement | 1 | |
S | PV share with neighbour behind the meter | Power Electronics | 4 | |
Need a precision amp (0.1 or 0.2%) meter? Fluke? | Power Electronics | 3 | ||
J | Infrared/Laser depth meter | Sensor Design & Implementation | 4 | |
P | esr meter | Test & Measurement | 11 |
by Duane Benson
by Aaron Carman
by Jake Hertz
by Jeff Child
