Hello everyone
I have 10 capacitors of the same value C_S charged to different voltages (2V,4V...20V).
I need to connect them to another capacitor C_L one at a time.
To put it more clearly, say from t=o to t=t1, C_S_1 should be connected to C_L.
From t=t1 to t=2*t1, C_S_2 should be connected to C_L, and so on.
I have with me a supply voltage of 2 and a clock signal of 2 V peak to peak.
If i use SCR s as switches(one for each of the 10 capacitors) and connect the other end of the SCRs to C_L, i can turn each one on and off in a sequence,using the clock signal.
The problem is will the SCR work for such low voltages (around 2V to 20V)???
http://forum.allaboutcircuits.com/editpost.php?do=editpost&p=296186
