Switching regulator circuit
pafrazier
Joined Jun 4, 2011
57
HI,
I need some help with with a circuit. I need a switching regulator. I need it to be in between an inductor and capacitor and just toggle the voltage on and off. I am note sure of the frequency yet. I can try different frequencies. Or if there is something simpler I am open for suggestions. The input voltage will be low. Less than a volt, but may increase over time. Any suggestions?
34,452
Don't really understand what you need.
What are you trying to do?
Switching regulator ICs are very common. If we know your requirements we should be able to help.
pafrazier
Joined Jun 4, 2011
57
Hi Carl,
I am trying to excite a circuit that I am working with. It seems if I toggle the connection between the cap and inductor some caps further along in the circuit charge. There is not much input voltage however it may build. Does that help.
