Switching power supply with a dead (0v) "low" side
Discussion in 'The Projects Forum' started by FalconFour, Jan 5, 2009.
  1. FalconFour
    Jan 5, 2009
    5
    I'm working on a curious project here. I tried searching the forum but I couldn't find any similar topics, so hopefully this isn't a duplicate, but if it is, please point me in the right direction. I've got a switching power supply from an Xbox 1.4 that is on the fritz. I just got it from someone that said it doesn't turn on. It was extremely dirty (roaches, to be exact) and I pieced it apart and ran all the electronic and plastic pieces (not mechanical or optical) through a short cycle in the dishwasher, then promptly dried it all off with compressed air. Visually, all the components are now as good as new. No leaking or bulged capacitors, no discolored ICs, no burn marks on the PCB, no blown traces - everything, visually, is absolutely perfect... well, except the annoying white "glop" all over the place from the factory...
    However, the original problem still seems to remain. The power supply is almost completely dead. I've got a bit of experience with electronics - I've fixed a few things, but just the same, I've been unable to fix a large stack of things as well (that I hope one day to understand how to fix). Armed with a cheap $3 digital multimeter from Harbor Freight, I've found that the initial stages of the AC filtering seem to work fine. The large (250v/470µF) filtering capacitor charges up to 166.4 volts (line voltage is 120v/60hz). But that's where the line stops.
    I checked the standby (3.3v) transformer for AC output (on the low side) while plugging the power supply in to line, and I got nothing. Zero volts. All the low side capacitors are also showing 0.00 volts. Everything is dead straight from the get-go.
    I've also got another power supply that exhibits exactly the same behavior. It was working just fine until I broke apart the high and low sides to try diagnosing another power supply... with, you guessed it... that same problem as well. After re-assembling and resoldering the components, the power supply no longer functions at all. And I've got another few PC ATX power supplies in the closet that, you guessed it, do the same thing. So to be able to understand why this happens on this power supply would help me fix a LOT of things.
    Armed with just a cheap digital multimeter, what can I do to, perhaps, fix this? :(
    edit: One minute, I'll try looking up some information about the Xbox power supply for those curious. ;)
    edit: Crap, there's no technical information available. I coulda sworn I made this edit days ago though...
  2. S_lannan
    Jun 20, 2007
    247
    i hope you are using an isolation transformer!
  3. FalconFour
    Jan 5, 2009
    5
  4. FalconFour
    Jan 5, 2009
    5
    Hm, I didn't expect I'd need to bump this. :(
  5. FalconFour
    Jan 5, 2009
    5
    Bump for any useful information...?
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Do a Google search for "ATX bench supply" - you'll find out that PC switching power supplies require a load on +5v before they'll regulate properly.
    If you've tried separating the various circuits in the PS, you may've fried the MOSFETs.
  7. FalconFour
    Jan 5, 2009
    5
    Well as far as the load on the supply, well... even with a load, it doesn't do anything at all. It acts completely dead - zero volts; the output filter capacitors never charged (and that would provide enough of an initial load to show *some* activity, charging the capacitors). Voltage in, nothing out.
    As for that other power supply I separated, I didn't plug it back in until I soldered the pieces back together (I was only using one side for testing)... then it just did the same thing that the Xbox supply is doing: bricked. Nothing. Zombified. If it blew the MOSFET(s), wouldn't they have, perhaps, gotten hot first? Or showed a sign of damage?
    Another thought I had was those awkward phototransistors that provide the feedback loop for the power supply... do those ever "go out"? Like, the LED can get too much current, or the receiving end can get messed up somehow? They seem like a sort of hackish solution...
  8. mik3
    Feb 4, 2008
    4,846
    63
    A schematic of the circuit (if you can find one) and a more accurate explanation of what is going on may help.
  9. Teaser
    Aug 30, 2007
    Do a quick check of the rectifier diodes.
