The TIP120's won't work with 5v relays, as they have too high of a saturation voltage.
The IRF510 is not logic level; it needs Vgs to be 10v to be turned on.
The TIP42 is a PNP transistor, which won't work either.
If you want something to work, you will need to use the suggested parts.
