switching polarity from + to - multiple times per second
Discussion in 'The Projects Forum' started by brandofryeman33@yahoo.com, Jan 7, 2011.
  1. brandofryeman33@yahoo.com
    Jan 6, 2011
    7
    Hey, my names brandon and im working on this project but i seemed to have run into a problem. Im trying to make a circuit to switch polarity multiple times a second. i want a motor to switch from positive to negitave and be able to control how many times a second it switches polarity. and also if possible i would like to be able to control the voltage as well. The project is not real big so i wouldnt want my circuit to be real big. Im not sure if this circuit would be possible but i hope someone could help me. I called a electrician and he told me i was crazy. Please help me. does anyone think that it could be done? '
    need the voltage to vary from 1.5volts to -1.5 volts. Also would like to be able to change it to what i need like: 1.5 volts to 0 volts to -.75 voltsand back to 1.5. I want to switch polarity multiple times a second. and be able to choose specific voltage/polarity at any given interval.
  2. CDRIVE
    Jul 1, 2008
    2,223
    99
    If you switch the motor polarity multiple times a second the motor is just going to sit there a buzzzzzzz. :D What are you trying to do?
  3. brandofryeman33@yahoo.com
    Jan 6, 2011
    7
    i didnt mean to say motor. I just need something like say a rod about 2 inches long and maybe 1/4 inch diameter, like a nail to switch polarity. One side negitave and one side positive at all times unless its neutral. thats all I want, so when one side is positive the other is negative. i want to be able to control how many times a second it switches polarity and control the voltage. i want the voltage to max out at 1.5 volts. and -1.5 volts. is this possible?
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    Is this something along the lines of the "levitating ball" projects, where the coil is energized to keep the item from falling out when held vertically?
    The reason I ask is there may be a simpler solution to your problem, or a more complex one. :)
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What's it for? Your 2"x0.25" iron rod will need a fair amount of energy to move it back and forth at several times a second. At 1.5V no chance.
    Why not do something like this.
  6. CDRIVE
    Jul 1, 2008
    2,223
    99
    Actually, this sounds more like the typical electromechanical 'Etcher' that was used as a high school shop project, back when they actually had shop. :D
  7. brandofryeman33@yahoo.com
    Jan 6, 2011
    7
    just say i have a C battery, with a wire on each side. also i have a pencil lying on the desk. i want to hook the c battery leads to each end of the pencil. I dont want it to move, just want to be able to switch polarity and voltage and be able to control how much voltage it has, and how many times a second it switches polarity.
  8. Adjuster
    Dec 26, 2010
    2,147
    300
    It would help to know what you are really trying to do. You seem to be reluctant to explain this, and we are left to guess whether this would be safe. For instance, a pencil could get very hot with a fairly small voltage applied to its graphite "lead".
  9. brandofryeman33@yahoo.com
    Jan 6, 2011
    7
    im just working on a school project. I know that im not the best explaining what i need. I just want somethimething (pos on one end and neg on the other) it doesnt matter what material its made from. I want to control the amount of voltage and the amount of times per second it switches polarity/voltage. i just wanted to experiment with different voltages and at different times during a second.
  10. brandofryeman33@yahoo.com
    Jan 6, 2011
    7
    .25 sec .50 sec .75 sec 1 sec
    1.5v -1.5v 1.5v -1.5v
    l l l l l l l l
    l l l l l l l l
    l l l l l l l l
    l l l l l l l l
    l l l l l l l l
    -.75v .75v -.75v .75v
    i want to experiment and put in whatever voltage i want at whatever part of a sec i want
    1v -.75v 1v -1.5v
    l l l l l l l l
    l l l l l l l l
    l l l l l l l l
    l l l l l l l l
    l l l l l l l l
    -.5v 1.5v -.5v .75v
  11. brandofryeman33@yahoo.com
    Jan 6, 2011
    7
    i was trying to draw straight lines but they got bundled up, just picture a line from top to bottom
  12. CDRIVE
    Jul 1, 2008
    2,223
    99
    What's the point? A graphite pencil is passive, like a carbon resistor. Changing polarity won't change a thing. Evasion is an art form and should be left to professionals.
  13. Kermit2
    Feb 5, 2010
    3,852
    968
    This will switch polarity for you as fast as you can push the switch.
    10-15 changes per second should be possible if you use a momentary switch, a toggle switch would be much slower.
    Time for some pencil torture :)
    Tell it you won't stop till it writes you a check. ;)
  14. Adjuster
    Dec 26, 2010
    2,147
    300
    Let's hope this IS nothing worse than a pointless exercise involving pencils or iron rods.
    Looking back on some ill-advised things I did with electricity as a youth, I count myself very lucky to have survived. This makes me cautious about giving practical advice, particularly to young people.
  15. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Perhaps the OP can state the purpose of this polarity switching? It begins to sound like a shocker.
  16. CDRIVE
    Jul 1, 2008
    2,223
    99
    When a poster is evasive it usually means his project falls into one of these categories.
    (1) Nefarious and verboten on AAC.
    (2) Automotive related and not permitted on AAC.
    (3) Free electricity schemes.
    (4) Wireless electricity schemes.
    (5) The OP thinks he's got an idea for the habitual postings of 'Perpetual Motion Machines'.
    (6) The OP thinks has invented something (conceptually) that's going to make him rich, despite not having any electronics skills.
    Numbers 3 through 6 fall into the category of... "I must be evasive, because if I divulge what I'm doing it'll be stolen from me"! :rolleyes:
    EDIT: Come to think of it, I'd rather have our 'yutes' messing with 2 through 6 than spending there entire lives playing video games and watching sports, instead of playing sports. This includes adults too! :D
  17. brandofryeman33@yahoo.com
    Jan 6, 2011
    7
    thanks kermit 2, is there any way to make a momentary switch for that and be able to switch polarity like thousands of times or millions of times per second? I really need something like that, but switch polarity very very fast. thanks for your help everyone...
  18. Kermit2
    Feb 5, 2010
    3,852
    968
    Thousands and millions of times a second is not what you indicated in your earlier posts. You said "you" wanted to control it.
    An oscillator and transistor switch arrangement are possible, but at anything more than 50-100 times a second, relays are useless. They can't switch fast enough.
    Tell us exactly what you need. What range of switching frequencies do you want.
    If you say everything from 1 Hz to Milions of Hz, then you can wait for someone elses help. THAT is not a simple project for shocking pencils with.
