Switching ON/OFF 3vDC
Discussion in 'General Electronics Chat' started by Jason Oliver, Apr 11, 2016.
  1. Jason Oliver
    Apr 11, 2016
    I'm looking to modify a Glade automatic spray dispenser to add a switch to it, so that I can turn it ON/OFF. It requires 3vDC to run. My question is does it matter if I have a switch rated for a certain voltage, as long as it is rated higher than 3vDC?
  2. Kermit2
    Feb 5, 2010
    3,854
    968
    Shouldn't matter. Such a low voltage low current device will not be hurt.
  3. ErnieM
    Apr 24, 2011
    7,443
    1,628
    There have been cases where a switch did not carry enough current to work reliably over the long term. A bit, say a few milliamperes, of current is usually necessary to insure any oxidation is burned away during normal use. Using say a medium power switch to make a voltage input, where no current flows is asking for trouble.
    Using just any switch is not a safety issue, but of it stops working after a few months you have something to try.
