Switching on and off a relay using the TL431
Discussion in 'General Electronics Chat' started by RodneyB, Mar 12, 2015.
  1. RodneyB
    Thread Starter Active Member
    Apr 28, 2012
    654
    14
    I have been working on a low voltage cut out switch and have had extensive help here on this forum. With the guidelines I think I have made progress.
    I am wanting to switch off a relay through a BC547 when the voltage drops to a Preset level.
    On the circuit I have been using the voltage between the cathode and ground stays at 2.7 Volts as I reduce the voltage it suddenly switches to 1o.6 Volts This is when the load must be switched out.
    I was using a IRF9540 but it never switches off and I have no idea why. Thus wanting to try another circuit.
    The circuit I was given is on a post of mine titled low voltage cut out
  2. Dodgydave
    Jun 22, 2012
    5,167
    776
    post your circuit... Ideally your going to need a comparator to set the switch off voltage.
    RodneyB likes this.
