switching on and off a relay at different motor speeds
Discussion in 'The Projects Forum' started by whitearrow, Jan 6, 2009.
  1. whitearrow
    Jan 6, 2009
    13
    can any one help me on an electronic circuit on how to switch a relay at a speed just a few revs above synchronous speed, switches off at synchronous speed and also switches off at high revs which the motor does not resist and apply breaks to it. does the LM2907 help??
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    How are you measuring your motor speed?
  3. whitearrow
    Jan 6, 2009
    13
    by means of a sensor and the frequency is determined by the output voltage from the LM2907
  4. Alberto
    Nov 7, 2008
    169
    36
    It is possible, but you will need an optical encoder mounted on the motor shaft. Encoder will supply the speed dependent frequency to your LM2907 and the analog out must be compared with a fix value. The comparator output will be the signal you could use to activate your realy (with a proper amplifier).
    Alberto
  5. whitearrow
    Jan 6, 2009
    13
    thanks for your help. i found it very helpful. thanks again!!!
