Switching MOSFETs are discharching?
Discussion in 'General Electronics Chat' started by Peytonator, Sep 18, 2014.
  1. Peytonator
    Thread Starter Active Member
    Jun 30, 2008
    105
    I am trying to build a simple MOSFET driver that converts a 5V pulse to a 12V pulse. To do this, I used an N-channel (2N7000) and P-channel MOSFET (BSS84), as shown in Fig 1.
    If the input signal is a 5V pulse train, I notice that the falling edge of the output pulses decay instead of dropping immediately to GND. Fig 2 shows the signal at point A, and Fig 3 at Vout.
    I suspect this has to do with the output capacitance of the P-channel MOSFET creating a low pass filter with the 100k resistor. However, if I change the resistor to 10k, it doesn't seem to affect the output that much. I also tried changing the P-channel MOSFET but the signal shape remained the same.
    Could you please advise me how to correct this issue?
    Many thanks
    Fig 1 (circuit):
    Fig A (point A):
    Fig B (Vout):
    FigB.jpg .
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    Is there a load in your circuit?
    As shown the output looks open.
    Try an 1K resistor on the output and measure again.
    Bertus
    Peytonator likes this.
  3. Peytonator
    Jun 30, 2008
    105
    Thanks Bertus - problem solved. Took longer to ask the question here than it did to solve it haha!
  4. wayneh
    Sep 9, 2010
    12,377
    3,231
    What does your pulse train look like? And what is its source-sink current capacity?
    [never mind, looks like you got it solved]
