Hey all !
I have an application where in the ULN2003 has to drive IR Leds and let a surge current through the IR led ! The high frequency that the uln will have to switch is between 100Khz to 50Khz (10uS to 20uS pulse width). How much voltage voltage loss can be see through the ULN2003. The uln will be given a Vcc of 3.3V and will also have input logic 1 = 3.3V.
No such information is given in the datasheet apart from Toff = Ton = 1uS Max
Kindly help
Regards
Kindly help
Regards
