Switching IC recommendations
Discussion in 'General Electronics Chat' started by machmanx, Apr 11, 2011.
  1. machmanx
    Apr 11, 2011
    So I'm trying to build a circuit that works like a 4PDT toggle switch (or more poles), but don't know which IC I should use. I'm thinking about using the CD4053, but perhaps there are better ICs to accomplish my task.
    The circuit is to switch a custom data device between 2 computers. The device should only be connected to one computer at a time, but the switching occurs when both computers are OFF, so no risk of damage. Device itself uses the Sata port on both comps, so I need to switch Transmit+, Transmit-, Receive+, and Receive-.
    So the IC will only be switching Data wires between two powered-down computers. So can anyone recommend me an IC to accomplish this task?
