Switching DC+ to DC- via Timer....Help
Discussion in 'The Projects Forum' started by Ghostz, Dec 30, 2014.
  1. Ghostz
    Dec 30, 2014
    I would like to create a timer that switches DC+ to DC- on a 24 hour cycle....
    Input power: 120V AC or battery powered DC...
    Anyone have any suggestions? or is their anything out there that does this?
    Thanks....
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    How about a purchased AC-line-powered timer driving a small DPDT relay with a line-voltage AC coil? I have a couple of these timers, and they can be programmed to turn on at a specific time, and turn off exactly 24hours later.
    The DPDT relay contacts can be wired like an H-bridge to reverse the polarity of a DC voltage:
  3. Ghostz
    Dec 30, 2014
    Thanks or the response.. i will check that out..
    What I am trying to do is this:
    Have a box that you can mount outside.. (battery operated would be best) It should have have a manual timer. It connects to a single wire that runs around the perimeter of the property...(but does not complete the circuit) So for instance.....
    I can set the timer for 6am -thewire would have a positive charge... then at 6pm it would switch and the wire would have a negative charge.......
    i that makes sense? I would like to do it the simplest way.......
