That's not a normal state. If you do that then the two sources will be shorted together.What will happen when two switches are ON?
If both sources are 12vdc then you can change the circuit slightly:hi...
if the sources is 12vdc from solar panel and 12vdc from recharger, is there a big changes on mr. crutschow circuit
is there change in resistors value or transistors types?????
thanks....
I just thought that if necessary it can be add two transistors and resistors to aviod that kind of status.That's not a normal state. If you do that then the two sources will be shorted together.
is this rightThe top left MOSFET needs to have the source and drain interchanged.
Also you can make both gate-source resistors 10K ohms.
can replace the switch in the circuit with a relay, if it possible can u draw the circuit please?Don't understand your question about 1/2 volt and relay?
Hello ,Hello All,
I would like to switch between two voltage sources, namely +24v and +5v. I have been trying to do with MOSFET. IRF530 and IRF5305, but i always fail. I have been using the following circuit that i found. http://www.electronics-tutorials.ws/transistor/tran_7.html . I will be doing the switching using MICROCONTROLLER.Please advise on this.
Or, Is there any other better way to do this ?
by Jake Hertz
by Jake Hertz
by Aaron Carman
by Jake Hertz
