Switching an IGBT with pulse unit
Discussion in 'General Electronics Chat' started by Electro007, Jul 14, 2016.
  1. Electro007
    Apr 4, 2016
    23
    Hi Guys,I have used the below circuit for swithing a N-channel mosfet and it works. I want to replace the mosfet now with a N-channel IGBT and was wondering if the connection in the diagram would be the same?
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    If the FET or IGBT is being switched rapidly then R1 should have a much lower value.
  3. Electro007
    Apr 4, 2016
    23
    Would you recommend 1k resistor?
  4. GopherT
    Nov 23, 2012
    6,309
    4,030
    @Electro007
    As alec said, R1 should be much, much smaller (10 ohms). The role of this resistor is to minimize noise (ringing) in other parts of the circuit, since no current is flowing other than to charge the gate capacitance (nano-farads), no limiting is really needed to protect the driver.
    Also, I am not sure I understand your drawing completely, is that + and - 12 volts? If so, you have a total of 24 volts going to the gate of the MOSFET? That should be limited to 20V max (preferably 15 v).
  5. #12
    Nov 30, 2010
    16,685
    7,326
    I read it as only 12V.
  6. Electro007
    Apr 4, 2016
    23
    Oky, but would the same wiring work on a n-channel igbt?
  7. GopherT
    Nov 23, 2012
    6,309
    4,030
    yes,You shouldn't need any changes.
  8. Electro007
    Apr 4, 2016
    23
    Thankyou
