Switching a pin on an IC from ground to Vcc
Discussion in 'The Projects Forum' started by PranavS, May 1, 2015.
  1. PranavS
    Apr 5, 2015
    6
    Hi guys
    I am currently doing a design project the requires me to to build a people counter. The signal coming in from my sensors are going to a decade counter(74ls192) which is activated with a rising edge.
    I need help with the switching of the pin from ground to Vcc when a high is received from my sensors.
    I have tried using BJTs which worked in simulation but when I built it, it did not work.
    Thanks for your assistance.
    Pranav:)
  2. #12
    Nov 30, 2010
    16,666
    7,314
    Hmmm...high is received from the sensor, high is required by the counter chip. What is the problem?
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    As always, a schematic would help us help you...
