Hi there...This my first post and I hope someone can answer my query. I have good electrical knowledge but my experience on electronics is limited.
My query is this:
I have a 12vdc LED, one leg is fed from a 12vdc positive supply.
The output to switch the other leg is 12vdc positive that changes to 0v to switch the LED on.
I have tried using a standard 12vdc automotive N/O relay but I believe this is causing problems with the electronic source that is changing the polarity in order to switch the LED via the relay.
Can any of you "Guru's" offer any advice or circuit details on how I can achieve it,
My query is this:
