Switching a High Power & Low Power Load Together??
Discussion in 'General Electronics Chat' started by joe426, Jan 28, 2012.
  1. joe426
    Thread Starter Active Member
    Aug 11, 2009
    39
    I have a PCB which is powered by 5v @ 1A and a motor pack which is powered by 50v @ 25A. Is it a good idea to switch these both "on" at the same time using a DPST switch such as this one? Or would there be a LOT of noise? Thanks!
  2. praondevou
    Jul 9, 2011
    2,936
    489
    It is possible to switch both supplies with one switch. If it can cause any problems depends on your application and layout/wiring.
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    generally not a good idea to combining sources. Your PCB will be sorrily messed up if there's a short at the switch. Your switch may be more than adequate, but in the practical world, shorts often happen due to improper strain relief, poor connections, etc.
