switching a 0v
Discussion in 'General Electronics Chat' started by jonisonvespa, Jan 6, 2013.
  1. jonisonvespa
    Mar 25, 2012
    49
    hi
    im trying to switch a 0v into a processor using a 4n25 i think ive finally understood how it works, am i correct in saying when my switch is made s1 i get 0v @ V0, i intend using 1k for both resistors.
    thank you
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    What is Vi? And what is Vcc?
  3. tshuck
    Oct 18, 2012
    3,531
    675
    Well, you won't get 0V, but you will get a logic 0...
  4. jonisonvespa
    Mar 25, 2012
    49
    sorry forgot to say
    vi 5v,
    vcc 5v
  5. tracecom
    Apr 16, 2010
    3,878
    1,396
    How did you decide on 1k for the resistors? 1k seems a little high for the input resistor and quite low for the output.
  6. jonisonvespa
    Mar 25, 2012
    49
    ok i will linit the current to led to 25ma using a 200r
    and limit the current into my ic to 10ma using a 500r (max current into the pin 40ma)
    am i still correct in saying i will get a low at v0?
  7. ErnieM
    Apr 24, 2011
    7,434
    1,625
    As someone who actually looked at the data sheet... go ahead and use 1K/1K, it will work fine like that. Looking at the Vishay data sheet C-E saturation is defined as 0.4V, so you should see less then that as your "0V" output, which is good for a logical zero.
  8. jonisonvespa
    Mar 25, 2012
    49
    thank you ernie
    my original idea was a bit complex adding a n type mosphet and relay to switch a ov to my pin but i then thought of this, i promise you i did look at the data sheet i have lots in my data sheet folder, im very new to electronics, i kinda of knew a 1k/1k will work but always wanting to reduce my current was my thought of using a 1k
    thank you very much
