I would like to use a solid state switch to discharge a bank of eight 250 volt/560 microfarad capacitors, wired in series, into a load. Currently, I am using a 40TPS12A SCR, rated at 1200 volts/40 amps to discharge a bank of four of these same capacitors, wired in series, into my load, which, effectively, is a short circuit. But, scouring the internet, it looks like the highest rated SCR is 1400 volts. Is there any other device that would satisfy my requirements?
