Hi I really have no clue what I am doing. Basically I want to have 3 switches attached to a microprocessor. Each switch when pressed will do something different like SW1 will trigger immediately while SW2 will go after 4 seconds and SW3 will go after like 10 seconds. Then from the processor it will be transmitted to a receiver and then the receiving processor will apply current to the correct pins. I was using MicroCode studio to do this but I am not really sure what I am doing. This is what I had so far. Any help would be greatly appreciated. Thank you!
If I am doing things completely wrong could you point me in the right direction. Like a good coding tut for microprocessors. Thx!
Rich (BB code):
Check:
IF Pin0 = 0 THEN SW1 ' If button connected to Pin0 is pushed (0), jump to label SW1
Endif
IF Pin1 = 0 THEN SW2 ' If button connected to Pin1 is pushed (0), jump to label SW2
Endif
IF Pin2 = 0 THEN SW3 ' If button connected to Pin2 is pushed (0), jump to label SW3
Endif
Goto Check
SW1:LOW 1 ' Turn off connected to PORTB.0
Pause 100 ' Delay for .1 seconds
High 1 ' Turn on LED connected to PORTB.0
Pause 500 ' Delay for .5 seconds
Goto Check ' Go back to loop and blink LED forever
SW2: LOW 1 ' Turn off connected to PORTB.0
Pause 10000 ' Delay for 10 seconds
High 1 ' Turn on connected to PORTB.0
End
SW3: LOW 1 ' Turn off connected to PORTB.0
Pause 60000 ' Delay for 10 seconds
End
