I am going to use switches as inputs to my registers. The problem is that I am using ttl ics and cannot use pull down resistors to prevent floating inputs. I know I can use pull up resistors, but then the default value will be 1 instead of 0 with a pull down resister and I need the default to be 0. How can I use a pull up resister without having to invert the outputs?
