Switcher can be used in a PCB circuit
Discussion in 'General Electronics Chat' started by Oussama Zaidi, May 30, 2016.
  1. Oussama Zaidi
    Mar 1, 2016
    53
    Hi
    Can you give me a circuit-breaker name or datasheet that I can use in a PCB circuit, with 24VDC of minimum voltage rating and 5A of minimum current rating ?
  2. kubeek
    Sep 20, 2005
    4,688
    806
    If you mean a step-down, then TPS5450 is one such chip.
  3. Oussama Zaidi
    Mar 1, 2016
    53
    No I mean a circuit breaker.
  4. kubeek
    Sep 20, 2005
    4,688
    806
    Ok, a switcher usually means a switch mode power supply. I know there exist circuit breakers that fit into holders for automotive fuses, I guess that is about as small as you can get.
  5. Oussama Zaidi
    Mar 1, 2016
    53
    Yes I found one: http://www.e-t-a.com/fileadmin/user...1_pdf_thermisch/1_pdf_englisch/D_1620_ENG.pdf
    but I don't know if I can use it in a PCB or not, I am using Eagle for the schematic and layout I don't think I can found something like that in its library, also like you said it is for automotive fuses I am afraid that it doesn't work for a standard use.
  6. kubeek
    Sep 20, 2005
    4,688
    806
    As usual, you would have to make your own footprint for that if you cant find one already made. What do you mean by a standard use? Automotive parts are more demanding in temperature, vibration, etc., so anything that is made for automotive will work without a problem on a normal pcb.
  7. Oussama Zaidi
    Mar 1, 2016
    53
    Thank you.
  8. DickCappels
    Aug 21, 2008
    2,768
    669
