Switched mode power supply
Discussion in 'The Projects Forum' started by ahmadmimo, Nov 5, 2011.
  1. ahmadmimo
    Dec 28, 2010
    I have a project to designe a power supply with this specifications:
    input 220v ac
    output: 24,12,9 or 5 dc volt
    range (1.2 - 2)
    I also need to understand the meaing of range here.
    I must use step-down transformer, compartor (with reverence volt) , Transistor.
    I'll be gratefull, if I get a help, Thank you......
  2. bountyhunter
    Sep 7, 2009
    2,498
    507
    You need to know the current for each output and the tolerance of each (like 3%, 2%, etc).
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Reverence voltage - I like it. :)
