Switched mode dc power supply
Discussion in 'Homework Help' started by iso_b, Jan 18, 2009.
  1. iso_b
    Jan 8, 2008
    5
    Help!
    I Need a diagram off a switched mode dc power supply and a description off how it works. On top off that i need the advantages and disadvantages compared with a conventional dc power supply...
    any websites links or help would be very much appreciated
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Since this is a homework assignment, maybe you could start by providing us with your own thoughts on the disadvantages versus the advantages of a switch-mode power supply?
    Our members would then be more inclined to assist you if you did.
    If you need some facts, you can start by visiting www.wikipedia.org and look at what is there on the topic of SMPS (Switched Mode Power Supply).
    hgmjr
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  4. mat sazilin
    Feb 6, 2009
    i think you can used SG3525 ic. it is good to used. im ready used this ic. to step up the voltage from 12vdc to 250vac. you can useda the project form http://sound.westhost.com/project89.htm. try your best.
