Switched-current ADC
Discussion in 'General Electronics Chat' started by amna, Jul 10, 2004.
  1. amna
    Jul 10, 2004
    what does switched-current ADC mean? Is it similar to ADC that is operated by current mode?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The ADC uses a comparitor internally. The external voltage drives a current through a resistor, and that current is finally matched by a current of opposite sign controlled by the electronics inside the ADC. The internal current usually comes from an R - 2R ladder, and increases in steps until the comparitor indicates either a balance or overrange. The current steps are the switched current part of the ADC.
  3. jibran
    Jul 16, 2004
    what does mean of inductance?
  4. susi
    Jun 4, 2004
    31
    hi,
    Definition of Inductance:
    A property of a conductor or circuit which resists a change in current. It causes current changes to lag behind voltage changes and is measured in henrys.
    thanks!
    Shumaila :rolleyes:
