I want to make a small radio where the battery is connected to the socket by inserting the earphones into a 3.5mm socket - to avoid having a separate on/off switch.
Is there such a thing as a normally open 3.5mm headphone socket? I can't find one which is described as such - but probably I just don't understand the schematics and how you would connect them to achieve this..
I have some sockets like this
http://www.rapidonline.com/Cables-Connectors/TruConnect-PCB-Jack-Socket-Stereo-3-5mm-20-0137
Could anyone tell me - can I use this to connect the battery when the earphones are inserted, and if so, what pins would be connected to what?
