switch terminology
Discussion in 'Homework Help' started by JDUK, Feb 15, 2012.
  1. JDUK
    Feb 15, 2012
    hi,
    as part of an engineering course I am asked to design a new thermostat. The question is based more on the property change of materials and not so much to do with the circuitry, however my design has to include a switch that is activated (to start up the heating system) when a constant power source is stopped (due to the temperature dropping so low that a semiconductor stops conducting).
    So basicly i just need to know the name of such a switch and possibly a few sentences describing it. just to recap i need a switch that is kept off when a power supply is running through/past it, but is turned on when the power stops.. thanks in advance!
  2. JDUK
    Feb 15, 2012
    alternativley if no such switch exists then could somebody tell me?
  3. n1ist
    Mar 8, 2009
    171
    16
    A relay should work. Use either a form B (SPST, normally closed) or form C (SPDT, use the normally closed contact) version.
    /mike
  4. JDUK
    Feb 15, 2012
    cheers mate!
