I am hoping to make some custom handlebar switches for my custom motorcycle. The bike has a 12v system.
I have purchased some metal momentary push button switches which I would like to use to replace the original switches. These I assume will be fine for Starter and Horn as these both currently use momentary push switches. Could anyone advice me the simplest way, adding maybe latching relays so I can also use the momentary switches for the following applications-
Heal lamp dip/high beam (switch between the two circuits)
Run switch (on/off)
Indicator/turn signals (on/off)
I have to point out I am not an electronic whizz and have no circuit diagram experience, I'm hoping someone can just advise what relays I would need for each system including their values etc?
Thanks in advance to anyone who can help, and sorry for being a complete novice! )
Stu
Run switch (on/off)
Stu
