Complete novice here --
I need to make a TTL switch/relay DC circuit (no real load) that does the following:
-Ignores short 'turn on' pulses, or a series of short pulses
-Time delay on in response to a steady 'turn on' signal (DC on, I guess)
- Immediate off when the steady signal is removed
The device involved is a rotating turret. If the turret is clicked into and held at a particular position, a downstream switch should be turned 'ON' with a short delay. If the turret is spun (clicking through several positions), the switch should stay off until the turret reaches a desired position and is held there.
Voltages involved are TTL 5V or so, but could be higher if needed.
Any advice will be greatly appreciated
