Switch Placement
Discussion in 'The Projects Forum' started by CircuitSurfer, Nov 12, 2011.
  1. CircuitSurfer
    Sep 19, 2009
    21
    I want to place a switch between a 1.5V battery and a small tweeter on a clock. Does it matter if I place the switch between the positive or the negative lead?
  2. jimkeith
    Oct 26, 2011
    539
    99
    not in the least
  3. williamj
    Sep 3, 2009
    180
    32
    A good practice is to place a switch on the positive (DC) or the hot (AC) side of any circuit. It's safer that way.
  4. BillB3857
    Feb 28, 2009
    2,402
    348
    Are you sure the tweeter will work on 1.5v from a battery? Many of them require a signal generated by the clock and will not work on DC
