Switch of car accessories based on V
Discussion in 'The Projects Forum' started by Scorp1us, Dec 21, 2013.
  1. Scorp1us
    Dec 21, 2013
    I have an always-on accessory in my lighter socket. But it keeps killing my battery if I don't run it every day. I was hoping I could use a simple circuit that would only work when the lighter is over 12V (meaning it 14V because the alternator is on)
    I think I would just need a transistor and a resistor?
    Many thanks!
    PS. I tried to search for this, but I didn't even have a good idea what to google.
  2. wayneh
    Sep 9, 2010
    12,379
    3,232
    Depending on your car, you may be able to program the outlet to be keyed instead of battery-direct. My minivan offers that option.
    Just about anything else you want to do to the vehicle will qualify as an automotive modification - a topic forbidden by the Terms of Service here.
    I'm not sure how the mods will feel about it, but I think altering your ACCESSORY to auto-off on low voltage should be an OK topic. We had a low-battery auto-off thread here recently. Search a bit and you should find it very useful.
  3. #12
    Nov 30, 2010
    16,671
    7,314
    I just tried a TIP 120 circuit. Too much Vbe drop. This will have to be done with a relay (if you can't just "tell the car" to make it a "run only" outlet).
    Zener, resistor, transistor as a switch, relay coil.
  4. GopherT
    Nov 23, 2012
    6,304
    4,027
    What load are you drawing (amps) from the cig lighter?
  5. Scorp1us
    Dec 21, 2013
    It varies, it is a dash cam, but supports a charging port for phones, which draws 1600ma when there is a phone plugged in, not including the dash cam.
    Why I want this is so I don't have to modify my car at all. I want to put the circuit inline - actually in the line to the dash cam - and let the acc port work as it currently does, when I need to charge my phone in the car. So TOS should not be a problem, as this would go on the dash cam wire. :)
  6. Alec_t
    Sep 17, 2013
    5,969
    1,135
    Can you confirm what the lighter socket voltage actually is when the engine is running?
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
    My prediction:
    Engine running, > 14V
    Engine stopped, < 13V
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    My prediction:
    I have a circuit on my other computer using a TL431 driving a PFET as a high-side switch which would do this. I can post it later today...
    #12 likes this.
