Switch from 1 inverter to another without disturbing PC
Discussion in 'The Projects Forum' started by DrEvil, Aug 6, 2010.
  1. DrEvil
    Aug 6, 2010
    How can I switch from a 600w inverter to a 1.5kW inverter smoothly without causing any damage and without my PC having to be turned off?
    would it be safe to use a DPDT relay like this one?
    and simply turn off the small inverter once the bigboy has started up.
    The small inverter is actually a UPS, the big inverter is connected to a 100ah 12v battery and so will last over an hour, I don't want to buy another 12v battery for 24v to power the UPS..
    The UPS will not run off the 1.5kW inverter (I'm guessing because it's "dirty power") so I need a way to switch
    edit: I guess it would be done automatically by using 2 DPDT relays
    Love Dr Evil. :D
