Switch For 200khz, 600w, 2% Duty
Discussion in 'The Projects Forum' started by kender, Jun 5, 2008.
  1. kender
    Thread Starter Senior Member
    Jan 17, 2007
    Relatively new to the vast field of power electronics here. I need to design a switch that will connect a 200kHz signal with 600W 2% duty power (12W average) to a load resistor. The switch will connect the resistor for a 100us at most. The initial signal comes from the unbalanced source to a hand-wound balun, so the voltages are flexible.
    Could you point me to some topologies for such switch?
    - Nick
