switch debouncing thecniques
Discussion in 'General Electronics Chat' started by athulascc, Jan 27, 2015.
  1. athulascc
    Aug 15, 2014
    88
    I am going to do micro controller based project.
    so I need to use push button.
    I am afraid about switch de bouncing effect because it causes to fail my before digital ic based project
    I used capacitor to reduce it but it wasn't work.
    anyone know good techniques?
    and please give me little explanation how it works
    I know we can use code in micro-controller to do that but I need hardware simple solution which can use any where?
    I like if there is ICs to do that
    many thanks
  2. ericgibbs
    Jan 29, 2010
    2,589
    389
  3. Bernard
    Aug 7, 2008
    4,235
    414
    I like fig 2 in PDF above , but use a schmitt trigger like 40106.
  4. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    You can use a SPDT switch driving a SR flip-flop made of 2x 2 input gates, or these days most people do debounce in the MCU firmware.
  5. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Debouncing a switch with a flip flop is risky because there is always the possibility that the output pulse may trigger your logic but not the flop. If this happens you will go about half nuts; that is responsible for my poor mental state.
    Jack Bourne likes this.
  6. MrChips
    Oct 2, 2009
    12,624
    3,451
    Use this:
  7. ErnieM
    Apr 24, 2011
    7,436
    1,625
    Debouncing a switch when you have a micro is very simple and easy. I do it by checking the buttons every so often, and if two readings agree I know the buttons are stable and goto whatever function the button does. For circuitry all you need is a switch and a resistor.
    For the buttons I use now a 25mS period works well: stops bounces from entering the electronics and is responsive enough to keep the user happy.
