Switch Contact Ratings
Discussion in 'General Electronics Chat' started by tracecom, Dec 30, 2014.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,878
    1,396
    There are two switches: one has a contact rating of .5A @ 50VDC and the other is .3A @ 125VAC. I am aware that ratings of all sorts are somewhat "iffy," but what I am wondering is there a way to determine what current the contacts would handle at 5VDC.
    Thanks.
  2. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    Usually they have a rating that gives and idea.
    http://en.wikipedia.org/wiki/NEMA_contact_ratings
    Also there is Dry Contact types where the contacts cannot switch the primary current, IOW only open or close when the load is not present.
    As a general rule, even if going with a lower DC voltage say, IMO, it is not always advisable to go any higher in current.
    Max.
  3. wmodavis
    Oct 23, 2010
    737
    150
    .5A
  4. tracecom
    Apr 16, 2010
    3,878
    1,396
    Is that your answer for both switches? Thanks.
  5. wmodavis
    Oct 23, 2010
    737
    150
    For the DC rated switch. Don't think you can extrapolate DC ratings from the minimum AC ratings you gave for the other one. Look at manuf specs.
  6. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    The fact of whether it is switching a resistive or inductive load factors in to a large degree also.
    Max.
