Hi everyone.
I need a circuit so that a toggle switch outputs a momentary signal, to use in flight simulation.
I found this circuit on a flightsim website.
Could anybody tell me if this optocoupler would work with this circuit please. http://www.maplin.co.uk/Module.aspx?ModuleNo=2228&DOY=19m10
He mentions in the article, that if you can not get an AC type, then you need to insert a diode in front of the coupler.
If it helps, here is the original article.
http://www.flightsim.com/cgi/kds?$=...ction to momentary switch action using relays
Thanks in advance for any help.
Colaboy.
Colaboy.
