Switch case help!!
Discussion in 'Programmer's Corner' started by paddy611, Dec 4, 2012.
  1. paddy611
    Oct 9, 2012
    25
    I am using switch case function in code.
    Can i use multiple statements in each case or it should be single statement in each case?
    thanks,
    paddy
  2. tshuck
    Oct 18, 2012
    3,531
    675
    you should have at least two statements per case: one/many to perform your desired operation, and one to break out of the switch statement, otherwise, you will fall into the next case!
  3. paddy611
    Oct 9, 2012
    25
    That means the code i have written below is valid?
    Code ( (Unknown Language)):
    1.
    2.
    3. switch(i)
    4.             {
    5.                case 0:
    6.                output_high(pin_B7);        //turn on LED
    7.                output_high(pin_A2);        //clock to latch
    8.                delay_us(100);
    9.                output_low(pin_A2);
    10.                delay_us(100);
    11.                output_low(pin_B7);        //turn off LED
    12.                output_high(pin_A2);       //clock to latch
    13.                delay_us(100);
    14.                output_low(pin_A2);
    15.                delay_us(100);
    16.                break;
    17.
    18. }
    19.
    thanks
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    1) You've never indicated what language you are using. C?
    2) The above code is not correct because you have a dangling block. You open the block with '{' but never close it.
  5. paddy611
    Oct 9, 2012
    25
    Ohhh I am sorry!!!
    I am using C language.
    I just want to confirm that the switch case supports multiple statements or not.
  6. WBahn
    Mar 31, 2012
    18,085
    4,917
    Yes, it does. As point out by someone else, it is almost worthless if you don't have multiple statements because you almost always need a break statement at the end of each case option.
  7. paddy611
    Oct 9, 2012
    25
    Ok thanks a lot for help!!!
  8. ErnieM
    Apr 24, 2011
    7,435
    1,625
